Topic: outboard processing (send/return loopback) with the ADI-2
It is possible to use an ADI-2 to send previously-recorded stereo audio through outboard gear, and then receive it back in so you can record the result. To do this, simply route your ADI-2's D/A outs to the inputs of your outboard gear, then send the processed signal into your ADI-2's A/D ins.
However, the ADI-2 does not allow monitoring of the processed signal. Its monitors are the same as its D/A output (and that's true for the front-panel headphone monitor too), so you can only monitor the signal that is being sent to your outboard gear, not the signal that is being returned.
A common setup for home recording studios is an HDSP 9632 plus the ADI-2, and you can indeed use the headphone monitor from the HDSP analog breakout cable, to monitor the outboard loop post-effect.
Setting up the cables is easy, but unless you're already experienced at using TotalMix, it can be a little confusing. Here's how to set this up:
1. Set up your headphones: find the pair of faders for the headphone signal coming directly from your sound card, in the bottom row of TotalMix. Set them to some safely low volume, like -24. Then while they're highlighted, find the pair of faders that are normally associated with the Analog Hardware Input from the ADI-2, in the top row of TotalMix. Make sure they're panned left and right, and set at 0.0.
2. Set up your send: find the pair of faders for playback over the ADI-2 (in the bottom row of TotalMix), and set them to 0.0. Then, while those faders are still highlighted, find the software playback channel you'll use to play back the pre-recorded audio, in the middle row of TotalMix. Set those faders to 0.0, and make sure all other faders are down. (You probably already have this set, because you normally monitor playback over your ADI-2.)
3. Set up your return: pick a free stereo channel in the bottom row of TotalMix, and raise its faders to 0.0. Also, control-left-click on the channel name (for both of the stereo channels), so it turns red. Then find the microphone inputs on the top row of TotalMix, and set their faders to 0.0, while making sure they are panned left and right. Also, make sure all other faders are down.
Finally: this isn't strictly necessary, but if you want to maintain the same line level, set the ADI-2 front-panel INPUT the same as the OUTPUT. I've noticed that there's a couple decibel loss even so. If someone knows why, please let me know. :)
That's it! You should be set up to monitor the signal returning from your outboard gear, as you send a stereo signal out of your ADI-2, through your outboard gear, and back into your ADI-2. Set up your DAW to play back the audio over the normal playback channel, and record the signal coming from the new channel you set up in Step #3 (the one with the names in red).
Once you've set this up, you probably want to save your settings. In TotalMix, click on the "Save" button under PRESETS, then click any of the preset numbers to save your settings.
