Topic: A little TotalMix help, please- mixing to two headphones plus loopback
I'm relatively new to TotalMix and and not quite yet grasping the best way to accomplish the following:
Create a mix using multiple inputs, and be able to monitor that mix in both headphone outputs simultaneously. I'd also like to record that mix via loopback. I'd like to be able to solo channels without it disturbing the mix, i.e. solo only affects the monitor (headphones, one or both), not the program mix.
I feel like this should be fairly straightforward, but am not finding the easy solution. I'm probably just not thinking about it correctly. If anyone can walk me through the best way to do this, I'd be very appreciative. Thanks!
David
