1 (edited by Arty 2011-10-28 07:27:43)
Topic: OVR Warning
When the track is playing with 44.100/16 indicator lights on the OVR
The track was recorded earlier and it may not be an overload.
This is normal or not?
Should the indicator OVR light up when you reach the maximum level 0db?
[img align=L]http://s2.ipicture.ru/uploads/20111028/sLnFZo2X.jpg[/img]
BabyFace  / Windows 7 pro 64 Bit
Re: OVR Warning
Set via F2. Depends on your setting.
3 (edited by Arty 2011-10-29 09:31:10)
Re: OVR Warning
I have not found the item in the settings (F2), which could control it (OVR limit). What do you specifically mean?
TotalMix Version 0.95
Re: OVR Warning
Who can clearly explain what is happening?
5
Re: OVR Warning
It says 'Full scale samples for OVR'. Raise the value to 3, 5 or 10 (more makes no sense) and the OVR indication will work differently.
Re: OVR Warning
maybe OVR it's already explained in BabyFace manual or
download DigiCheck and read about in the "Help"
"Levels higher than 0 dBFS: Over without an Over"
regards S-EH
Re: OVR Warning
My question was a little about that.
I don't understand why at the correct digit level to 0 db I have indicator lights up overload?
Regardless of the setting in "Full scale samples for OVR"
Re: OVR Warning
It also depends on the material you are playing back... If it is from a commercial CD, google for "loudness wars"...
Re: OVR Warning
The track was recorded at the studio (live performance) with the help of a mixer in the format of 16/44
