Topic: Automatic buffer setting
Hello!
I am using an RME Babyface with the latest drivers. Is there any way to automate the buffer setting when opening an audio application? I mean, for example, every time I open Cubase the buffer setting to be automatically set to 128samples but when I open Melodyne, for example, the buffer setting is automatically set to 1024 samples, without me having to do it manually..
And a request.. In a future version of TotalMix, could you move the 'record EQ' option into Totalmix instead of the Control Panel, so that we do not have to switch windows in order to enable/disable it?
Thanks!
