Topic: Channel labels in Logic messed up after updating drivers?
Hi
I am having problems with the channel input/output labels in Logic after updating to driver 1.62. E.g. Channel 1 - "Input 1" now says "Analog 1-8", and most of the other labels say "Adat 9-16"?? Of course, I can rename them to what ever I want in Logic but it would be nice if the channels showed up correctly from the driver in the first place.  Any clues what went wrong?
Rune
Re: Channel labels in Logic messed up after updating drivers?
Here is an image of how the I/O labels now look
Yes. I have the same issue.
There is something fishy going on. Take a look at Audio MIDI setup too for some new stuff.
RME Fireface UFX
Mac Mini 2.6 GHz 16 GB Ram Areca RAID | MacBook Pro 2,2 GHz 16 GB Ram | OS 10.10.5
You are still running Snow Lepoard? I thought maybe it had something to do with Lion but thats only me guessing.
Yes this is in 10.6.8.
RME Fireface UFX
This certainly looks like a bug to me. RME Support, do you know anything about this?
7
Sorry for the inconvenience. This has been an oversight on our side while changing the internal structure for optimized Lion performance. A new driver that has the correct channel names again will be available today or tomorrow.
OK, thanks!
Its not a huge problem as I can always rename the channels to whatever I want, but its a lot easier with the names right in the first place.
Thank You!
I Liked the organization that appeared in Audio MIDI Setup thou. :-)
RME Fireface UFX
10
I uploaded release candidate 1.63 here:
https://archiv.rme-audio.de/download/dr … ac_163.zip
Someone dares to try it?
I must say that I am impressed by how fast you fixed this! :-) I have tested this driver a few hours now and I can't find anything wrong with it. Great job!
PS: Please, let us know if this version does not make it to release.
Thank you!
I just bought ufx and use it by firewire cable with my mac pro 10.6.8.
I installed 301 x86 driver, 1.62 usb driver, and 2.61 usb flash update.
After that, i updated firmware on flash update program.
But i have same problem (input1 1-8)
So i installed that usb driver 163.  But same!!
Whats wrong to me....
Maybe thats not a firewire driver?
This is the USB version of the driver.
Here's the firewire one:
http://www.rme-audio.de/forum/viewtopic.php?id=12914
Good Luck!
RME Fireface UFX
