Topic: RE: Babyface Preamp Bypass question
I've seen a couple of similar posts but my post is a little different.
1) My RME Babyface is en route to me as I write this. I have a Focusrite ISA One Analog. I wish to bypass the mic preamp at times to use my standalone preamp instead. I have read that to do this, I need to turn the input gain to 0db, thereby preventing the preamp chip from kicking on. I also believe I understand that the preamp circuit is still somewhat live though in some way, What type or amount of any additional noise can I expect to pick up with setting this up with my ISA One.
The only thing I will be recording is narration dialogue for documentary projects. I have a studio professionally treated for acoustics, so my environment is ideally quiet.
2) Although I intend to use my Focusrite ISA One specifically to preamp condenser microphones, and therefore not drive the preamp hard at like 80db of gain, will there be an issue with the Babyface taking on the signal. I believe that I have heard that the Babyface may have a maximum input signal of +12dBu and that the ISA One is capable of outputs higher, like in the +20dBu range. I had an older M-Audio Fast Track Ultra I tried before this and I think the ISA One was too powerful and clipped my DAW without much gain on the ISA One at all. Will the babyface work well?
Thank you for any assistance,
Trying to understand if this is going to work before I would open the product box. I have heard great things about this little Babyface.
Epiphany
