1 (edited by roberts_1 2011-11-22 20:09:59)
Topic: Babyface strange input Volume
Hi
Extension cable is not connected and the levels at AN1/2 channel
are at -70 db. Gain and EQ are also OFF.
Why?
[img align=L]http://s5.ifotos.pl/img/2png_rpweesa.png[/img]
Re: Babyface strange input Volume
Check cords for connections, but sometimes I pick up more noise than at other times. I guess there is electromagnetic interference and better cords that are more shielded may help that out, although I use balanced connections.
Mine never gets that bad though but can be in the '90's instead of the 108 level.
There is no cables and that's my problem. Is my unit faulty?
5
You mean 'breakout cable is not connected'? Peak Meter at 192 kHz gives that value. Check the current sample rate, then read the manual chapter 26.6.
Thank You.
Problem resolved at 48 kHz.
Chapter says -82 anyway at 192 kHz.
My level is 10 dB more.
7
And I wrote 'Peak'. Change the level meters to RMS.
Thank You Matthias, glad to gear that "alles ist gut" smile
I'm still learning this baby.
