Topic: can I use UFX as crossover.
Can I use UFX as crossover, when i use it in standalone or with DAW.
I need seperate output for sab and bi-amp. Do I need Loundspeaker proccessor?
Thank you.
2 (edited by kasaudio 2011-11-24 22:00:25)
Re: can I use UFX as crossover.
With proper software you can use UFX or whatewer sound card for whatever in audio. I use 2xFF800 for sound system processor (eq-crossover-alignment delay-compressor/limiter) for quite a long time now. It is used for FOH sound system and up to 6 monitor lines. (8 ch input -> 11-12 ch output). In that case computer is the "brain" and audio interface only provides audio streams.
In standalone mode you don't get the functionality needed for such purpose (or perhaps you can somehow run a simple subwoofer/satellite audio system - which is not the case you describe).
If such approach is not the "goal" of your life, get yourself a loudspeaker processor.
regards, kasaudio
