Topic: FIREFACE Drop Out Probleme, inkl. Monitoring Latency Mon
Hallo,
leider habe ich immer wieder drop-outs bei der Aufnahme oder auch nach einiger Zeit beim Aspiken meiner DAW (Ableton).
Ich nutze eine Fireface 400 und eine Fireface 800.
Anschluss FIREWIRE 800 - FIREWIRE 400 - PC
Der Latencymon Zeigt mir immer wieder diesen Fehler an. Leider kann ich nichts damit anfangen um zu sagen woran das liegen könnte.
Was ist der Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation????????
Und woran kann das liegen.
Vielen Dank....
Herry the bo
PC Daten anbei:
________________________________________________________________________________________________________
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines belonging to a driver running in your system appear to be executing for too long.
LatencyMon has been analyzing your system for 0:05:38 (h:mm:ss)
System Information
Computer name:                                        HERRYBO
OS version:                                           Windows 7 , 6.1, build: 7600
CPU:                                                  GenuineIntel Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz
Logical processors:                                   4
RAM:                                                  3488661504 total
VM:                                                   2147352576, free: 1933033472
CPU SPEED
Reported CPU speed:                                   2833 MHz
Measured CPU speed:                                   2300 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED KERNEL TIMER LATENCIES
Highest measured kernel timer latency (µs):           466.9924
MEASURED SMIs AND CPU STALLS
Highest measured SMI routine or CPU stall (µs)        11.2049
REPORTED DPCs
Highest DPC routine execution time (µs):              354547823365.2500
Driver with highest DPC routine execution time:       Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Highest reported total DPC routine time (%):          26190.1766
Driver with highest DPC total execution time:         Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in DPCs (%)                          26191.8446
DPC count (execution time <250 µs):                   5500699
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-999 µs):                51438
DPC count (execution time 1000-1999 µs):              0
DPC count (execution time 2000-3999 µs):              0
DPC count (execution time >=4000 µs):                 0
REPORTED ISRs
Highest ISR routine execution time (µs):              35.2509
Driver with highest ISR routine execution time:       ataport.SYS - ATAPI Driver Extension, Microsoft Corporation
Highest reported total ISR routine time (%):          26190.3011
Driver with highest ISR total time:                   Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in ISRs (%)                          0.7725
ISR count (execution time <250 µs):                   4712634
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-999 µs):                0
ISR count (execution time 1000-1999 µs):              0
ISR count (execution time 2000-3999 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count:                 none
Total number of hard pagefaults                       8
Hard pagefault count of hardest hit process:          3
Highest hard pagefault resolution time (µs):          81673.3826
Total time spent in hard pagefaults (%):              0.8800
TODO: Number of processes hit:                        0
PER CPU DATA
CPU 0 ISR count:                                      1177979
CPU 0 ISR highest execution time:                     33.4387
CPU 0 ISR total execution time:                       2648022.7716
CPU 0 DPC count:                                      1910276
CPU 0 DPC highest execution time:                     983.4480
CPU 0 DPC total execution time:                       9188169.7952
CPU 1 ISR count:                                      1182037
CPU 1 ISR highest execution time:                     29.6706
CPU 1 ISR total execution time:                       2597638.5220
CPU 1 DPC count:                                      1203610
CPU 1 DPC highest execution time:                     849.7479
CPU 1 DPC total execution time:                       7118500.3688
CPU 2 ISR count:                                      1181831
CPU 2 ISR highest execution time:                     35.2509
CPU 2 ISR total execution time:                       2639097.7147
CPU 2 DPC count:                                      1211941
CPU 2 DPC highest execution time:                     720.9879
CPU 2 DPC total execution time:                       7331407.2880
CPU 3 ISR count:                                      1170787
CPU 3 ISR highest execution time:                     28.1941
CPU 3 ISR total execution time:                       2573625.3501
CPU 3 DPC count:                                      1226311
CPU 3 DPC highest execution time:                     354547823365.2500
CPU 3 DPC total execution time:                       354555268657.9066
Re: FIREFACE Drop Out Probleme, inkl. Monitoring Latency Mon
Werden noch weitere Infos benötigt?
Google this and you will find an explanation for this...
This is not a RME-issue.
Zapp
ps: Ein Freund von mir mit einem I7-quadcore hatte ein ähnliches Problem, bei dem der erste Core mit nahezu 50% ausgelastet war und dadurch ein vernünftiges Arbeiten nicht mehr möglich war. Das ist ein "Windows-Problem"!
Zapp
Hey Zapp, ich habe das bereits gegooglet, und 90 % sind irgendwelche Beschreibungen zur Virusentfernung, einen Virus kann ich komplett ausschliessen.
Da diese Meldung auch nur kommt, wenn einer der Fireface angeschlossen ist, gehe ich schon von einem RME Fehler aus.
Mittlerweile habe ich die Firefaces auch mit einem BND Kabel gesinnt, was vorher nicht der fall war.
Gestern konnte ich mal etwas länger Musik machen....allerdings jedesmal wenn ich ein UAD Plug In öffne, kamen die Drop Outs....
Muss dann immer kurz die Audiokarte in der DAW deaktivieren und wieder aktivieren, dann sind die Drop Outs weg.
So richtig zufrieden bin ich noch nicht......aber es wird besser....
m.
Wdf01000.sys ist der Windows Firewire Treiber. Die DPCs entstehen durch die Nutzung des Fireface.
Besser die DPC Latenzen *ohne* Audiointerface messen und auch den DPC Latency Checker nutzen (Latenzen entstehen nicht nur durch DPCs).
Außerdem mal versuchen Live auf "Echtzeit" Priorität anzuheben. Dazu den entweder den Task-Manager "als Administrator" starten, oder den Haken unterhalb der Prozessliste setzen (Prozess aller Benutzer anzeigen), sonst fehlt die Berechtigung.
