Topic: Audio Drift - sync issue? Fireface 800
My audio recordings are drifting. I am not very techy, but I believe based on my web searches, that this is the correct terminology for the problem I am having. I have search the RME forums and can't find any help for this.
I own a mac mini. I have tested this issue in Cubase and Abelton Live.
My Fireface 800 is set as the master clock source. It has the latest firmware installed.
If I play a midi file routed to an external keyboard and record the audio performance, the audio recording slowly goes out of sync with the midi. Put another way, if I line up the first note of audio file after recording with the first note of the midi file, as I observe the rest of the audio, it slowly goes out of sync with the midi.
I have done another test. I recorded the same performance from my mpc2000 sequencer into three different audio lanes. If I line up the beginning of each audio file, they slowly go out of sync with each other --- some recordings are slightly slower or faster than others. The MPC2000 is a rock solid sequencer as far as time goes, so that is not this issue.
I do not know what is wrong. I do not know much about sync, word clock, or any of this. I made sure cubase was set to external sync so that the program is slaved to my Fireface 800.
Any help would be greatly appreciated.
Thank you.
