Topic: Fireface UFC Dead after flashing to 2.64
Unfirtunatly, when flashing my UFX to 2,64, I had the error 90000000 first and at the second try error 80000000.
When I So, no update, after I restarted the UFX, I have the blank screen with almost every led on.
Is there something to do to fix the problem?
THe UFX doesn't seems to connect to the computer (Mac Os X.6.8)
Thanks,
Livfall
Re: Fireface UFC Dead after flashing to 2.64
That sounds like the UFX just died while you tried to update the firmware. Usually, even with the screen blank, it can be used via the computer to re-flash it. If the computer doesn't see it at all it must be dead.
