Topic: babyface sample rate changes
hey guys,
something weird happend-i was running cubase 6 and the bf as interface. the dell laptop went to sleep and as i restarted, cubase told me, the sample rate had changed and wanted to change the projects rate as well.
however, the totalmix showed 32.0k (as opposed to formerly always 44.1k). i disconnected the bf, reconnected, 32.0k. reboot. 32.0k.
how can i change that?
thanks in advance,
pete
Re: babyface sample rate changes
No, I would say that sleep mode does not save the settings in the Fireface USB Settings program, so it defaulted by to the lowest rate. Do not allow the computer to go into sleep mode, you might as well turn it off and restart it, so the Settings (all of those in Windows and Windows saves) are saved the next time you start the computer.
