Topic: Is there a Pod HD / Babyface conflict?
I just got a Pod HD as a gift. Although not the best thing I have used.... I do find some of the clean guitar settings and a few other things very useful and could use it.
However It is crashing my compter!
It seems to be a conflict with my Babyface.
If I shut down total mix, unplug my Babyface and open my daw software (reaper) I can record tracks ... But if I record via USB from the Pod ...With the Total mix open ... even with the Babyface unplugged after a while .....BLUESCREEN!!!
I I record with the Total mix shut down... Babyface unplugged ... no problem.
But when I plug the Babyface back in to do other tracks with it..... BLUESCREEEN!
If I shut down the software and start over every time I switch between the two I can get away with it. (I think)
Anyone else had problems with lines 6 stuff? Had the same problem with a UX1 I had for a while after getting my Babyface.
However.... the POD goes way before my Babyface!
The few things I would use the Pod for makes it seem this one is headed for ebay!
