Topic: ASIO issues with a dual-HDSPe-MADI-card system
I am working on a playback/recording tool using the ASIO interface on a Win7 machine with 2 HDSPe MADI cards. I am implementing my own ASIO manager code (i.e. all the low level ASIO client calls to load drivers, create buffers, control I/O etc.). The application has a requirement to support 128 channels input and 64 channels output (and it might go up to 128 input and 128 output).
However, when I try to create the necessary buffers for ASIO I/O for 128 input and 64 output channels (i.e. 192 buffers in total), the ASIO call
ASIOcreateBuffers(pASIOBufferList, TotalChannels ,preferredBufferedSize, ASIOCallbackList)
where TotalChannels=192, preferred BufferSize=256, sample rate=48K and 16-bit sample size
is always returning the error ASE_InvalidParameter (it actually causes a BSOD once every 10 calls).
After further testing, I have discovered that the same code (with the same sample rate and size) is working fine for up to 64 inputs and 64 outputs (total of 128 channels) and nothing higher. So I would like to understand if there is a hardcoded limit for the number of channels/buffers you can create via your ASIO driver for the HDSPe cards or whether there might be another issue I am missing.
Other notes:
-    The PC is a pretty high-end quad-core machine with Win7
-    I have installed all the latest drivers from the website for the cards
-    Both the Hammerfall DSP settings GUI and mixer show the 2 cards and channel count/settings correctly
-    The ASIO calls to get the number of maximum number of input and output channels return 128 and 128 respectively so theoretically we should be able to go up to 256 total channels/buffers.
         ASIOgetChannels(&drvMaxInputChannel, &drvMaxOutputChannel)
-    The same code base has been used without problems on other ASIO cards/drivers for about a year now (although obviously for a smaller number of channels)
Re: ASIO issues with a dual-HDSPe-MADI-card system
Not sure on the code aspects of what you are doing.
You should make sure that both cards are proper clocked to a single clock source.
If your just using the cards headphone out and do not have MADI hooked up then you should take the WC out of card 1 and go to the WC in on card 2. Card 1 master/Internal and card 2 to Auto Sync/WC input as the clock source.
Software programs can act pretty strange when the 2 cards are not synced correctly. I've come across that allot with people live MADI setups where they did not have the 2nd card plugged into anything since they were not using a console that night with more than one MADI port.
AFIAK there is a still a limit of 255 individual I/O addressable with ASIO.
You can official use up to 3 MADI in system as long as the total number of assigned I/O does not accede 255 it will work fine. A 3 card setup is popular for people doing 96k recording.
3 card setups have worked fine in PCs going back 5 or more years now so I don't think your computers speed has a bearing on the issue.
You might want to test the dual madi card recording setup with some other software such as Reaper or Cubase to help rule out any motherboard compatibility issues. Especially if you are using a mix of PCI and PCI-e Madi cards. Some nwer Intel chip sets have flaky  PCI implementation.
Have you confirmed that the cards are both using the most current firmware?
You only mention anything about the drivers.
Thanks Chris
Chris Ludwig
www.facebook.com/RMEAmericas
Twitter @RMEAmericas
