Topic: consistant loud white noise with multiface on Windows XP SP3
Setup
OS - Windows XP SP3
Intel Pentium D 3.2 Ghz processor (HT turned on)
4 GB Ram
Geforce 210 1 GB DDR2 graphics card
PCI HDSP card with Multiface
Issue - there is lof of constant loud white noise after installing the latest drivers, instrument sound is not audible yet all
have done the following things but no luck
I have reseated card in a different slot away from all of other cards
changed firewire cables
changed instrument cables
directly powered multiface
worked fine when i had old driver.. am hesitant to install old driver as am afraid it might mess up the setup.
any help/advice will be greatly appreciated.
KK
Re: consistant loud white noise with multiface on Windows XP SP3
Did you update the HDSP card firmware to match the driver? Check which version numbers are reported on the "About" tab of HDSP Settings.
yes, I updated both firmware and drivers.. updated firmware first and then driver .. does the sequence matter ?
driver - 12/02/2011 version 3.27
Windows WDM, GSIF and ASIO 2.0
hardware revision 55
lock registry uncheked
optimize multi-client mixing checked
regards,
KK
any feedback guys.. this has been very frustating.. I tried all means and cannot get clear sound out of this unit. Checked all outputs no luck.
KK
