Topic: Fireface UFX / TotalMix: Routing issue.
Hi all,
I'm posting there because I get a basic routing issue ... I want to route a guitar signal to the AES software output and then route itself to the AES hardware output to finally route the latter to the AES input of an effect. I am on Cubase studio 5.
[q]Guitar signal -> AES software output -> AES hardware output -> AES input of an Effect[/q]
The thing is that i cannot route my guitar signal to the AES software output ... here is how I process:
1/ How i set the cubase output:
http://blindprod.free.fr/audiofanzine/rme_issue/img.1.1.png
2/ How i route my signal to the AES software output:
http://blindprod.free.fr/audiofanzine/rme_issue/img2.png
3/ When I play, nothing is provided to the AES software output:
http://blindprod.free.fr/audiofanzine/rme_issue/img3.png
4/ However, when I set the AN 1/2 software input, that works:
http://blindprod.free.fr/audiofanzine/rme_issue/img4.png
I also noticed that no other software output actually work ... (only the 1/2 AN).
Of course, i could route my guitar signal to the 1/2 AN software output and then route itself to the AES hardware output ... that works, but that condamn me to use only 1 software output at time!
Could please help me!
BRgds,
Eddy.
Re: Fireface UFX / TotalMix: Routing issue.
Hi Eddy,
I don't think it's a problem in TotalMix as the signal never gets to the mixer. Please try deleting your busses in Cubase, go to the Device Setup page and hit the "Reset" button, then create the busses again.
3 (edited by EddyA 2012-01-12 12:10:09)
Hello Jeff,
Thx for this advice, that works now ... fuck*** cubase, it did not handle the Fireface when busses are manually set (i.e. editing his own busses).
Thx a lot!
Eddy.
EDIT: Ok, I well understand what happened: When the track is set to "mute" and then to "solo", the track is not played, certainly a bug of cubase ... you have to remove "solo", then to remove "mute" abd to set agin to "solo". That activate the output/input of the relative track ....
