Topic: Max lenght fw 800 cable for FF800?
This might have been asked, but is 15feet risky for fw800 cable lenght (w fireface 800)?
What is the max lenght i can go safely?
Re: Max lenght fw 800 cable for FF800?
Check this out !!!
http://www.unibrain.com/Products/p1394/long-cables.htm
Cheers,
Dimitri.
I use cables longer than 15 feet and never noticed problems, and I have lots of I/O and 2 hard drives on the chain.
hope this helps
Thanks for this.
Do you mean two fw hdd with the same chain as the fireface??....
I thought putting a hdd was a no-no.
yes I mean that. I have a FW800 MacPower Taurus dual HD and I always use it with my FF800. I use one HD for recording and the other for playing back samples. Most of the time I work @ 44.1/48 and my projects are medium size (24 to 48 tracks). I also use a Rosetta800 for the conversion and extra outputs and sometimes I even connect a FF400. In MY case I did not experienced problems with the FW800 chain.
