Topic: hdsp 9632 sampling rate problem
I'm facing a problem with my hammerfall 9632. Just recently have reassembled a new win7 based pc. After installing the hdsp with the most recent win7 drivers I'm facing the following problem: by default the board is always a low sampling rate, whenever I have a file with a higher sampling rate I have to select it manually, if I stop the track and I restart the same track I have to select again the correct sampling rate since it went again to the lowest level.
What do you think? Is it a driver problem or the hardware?
thank you for the help
Re: hdsp 9632 sampling rate problem
Which sample rates exactly are these? Which software are you using and which driver version is installed?
Indeed I'm a newbie. My problem is after installing the latest drivers for win7 and I select the sampling rate with the software that comes with these drivers. The strange is that on my previous computer everything worked well, them I just re formated the pc replaced the mother board and problems appeared.
