Topic: Babyface -- analog calibration
Hello all,
I am setting up the babyface analog I/O using some balanced xlr to go out and back from some +4 gear and was having some issues with calibrating the levels. Finally I just did a loopback and realized it was in fact the Babyface unit itself which has the levels coming in about 3db hotter than going out. I have made sure the output level is set to 0 and the input coming back is set to 0 and yet it comes back about +3 higher. From what I can see I am not double bussing it out it looks correct in Total Mix. Whats the deal? How do I calibrate it to be the same level going out and returning. I want to be sure this is accurate before adding something into the chain. I cannot seem to find any other info about a calibration setting
Thanks!
Re: Babyface -- analog calibration
You will find the exact values in the manual, and you can use Totalmix to adjust levels, if required.
Isn't it somehow connected with Main Out gain, which is by default set to -3dB in TotalMix settings?
