Topic: xlr breakout cable w/ AIO - driver settings
Hey all.
I have a 9632 with the xlr breakout cable and the AIO expansion boards. My monitors are connected to two of the AIO outs, with the xlr feeding a subwoofer (which isn't used very often).
My question is: Should I uncheck or check the "breakout xlr" option. I realise that when checked, it will lower the level by 6db, however I'm unsure which option I should be choosing (just got new monitors and don't want anything untoward to happen).
It's probably a silly question (if it matters at all, the sound seems the same, only louder when unchecked obviously), and I've searched and searched for a clear explanation but to no avail.
Thanks in advance.
edit.. i meant the AO4S expansion board.
