Topic: Moving a HDSP 9652 from Windows XP to Windows 7
Hi, I'm slightly confused on the driver versions and firmware. I currently have a HDSP 9652 (old revision) on Windows XP with driver version 2.83. I want to move this card to a new computer running Windows 7. What is the correct driver version to use and must firmware first be upgraded on the XP?
Am I limited to ASIO drivers and 32-bit Windows7?
Re: Moving a HDSP 9652 from Windows XP to Windows 7
The latest driver is 3.27, the card will likely require a firmware update, and you are not limited to 32-bit W7.
