Topic: Can't open settings of Multiface I on MacBookPro5,1 Intel Core 2 Duo
Hi
I have Multiface I on  MacBookPro5,1 Intel Core 2 Duo. I install newest drivers for it. Mixer works fine but HDSPe settings is just on toolbar and when i'm pressing it nothing happen no window no reaction. I try also to install older drivers and no result as well. Any idea ?
Greetings
Re: Can't open settings of Multiface I on MacBookPro5,1 Intel Core 2 Duo
Which driver have you installed exactly?
Version 3.01 11/25/2011    hdspe_x86_301.zip
I also try to run my system in 32 bit kernel but also no change. Im working on Leopard Snow.
Any solution ?
Greetings
Is the HOST LED on the MF on or off? WHich driver was installed previously?
Have you tried removing the driver and reinstalling?
Host Led is on. I didn't have any drivers before i just recently bought that soundcard. I install the newest once from your web. I tryed couple of times, also version hdspe_x86_272, but no change.
Greetings
8
Host LED on means the mixer does NOT work. The whole MF does not work.
Does it mean that the sound card is broken or that software is not working ?
Greetings
Im using that soundcard with PCMCIA to Express Card converter, it was working on pc, maybe there is some firmvare problem with that card or it should be just other one?
Maybe some upgrade like this woul help:
http://www.rme-audio.de/en_downloads.ph … iver_hdspe
Greetings
Could be all becouse of pcmcie to express card converter ?
Greetings
