Topic: Totalmix question
I read thru the manual and couldn't find a definitive answer on this so I'll ask the pros.  Can I control faders that are attached to a none "highlighted" sub group?  Basically I have several instruments connected to my Fireface 800's inputs (1-5) and I also have two separate effects chains setup as send/returns (inputs/outputs 6-8).   Is it possible to control the input faders for each subgroup (effect chain) simultaneously?  I am using this in my Live performance and I don't want to have to reach over for a mouse to "manually" select the subgroup.  Instead I would like to use my midi controller's (Maudio Keystation Pro) faders and knobs to do this.
Thanks in advance
S
Re: Totalmix question
This is not possible, the faders only work for the current subgroup. But you could easily change the submix from your MIDI controller as well. Additionally - why not simply control the single output fader in the third row instead?
