Topic: Will the FF UC + an external USB hard drive need a bigger buffer size?
I recently recorded a concert to my MacBook Pro using Reaper and a Fireface UC.  The project was fairly busy as I was using all 8 ins and 8 outs on the UC and then recording straight to a USB external hard drive.  Does using both USB ports in this way doubly drain the CPU power?  Although I set the buffer size to 512 samples, I was horrified to find little buzzes and glitches had been recorded occasionally throughout the audio files.
Eastwood Records
www.eastwoodrecords.co.uk
