Topic: Fireface not recognized on imac - "Host" light constantly on.
Hi all
I'm having a big problem with my iMac. It won't recognize my fireface 400 sound card from RME. The weird thing here is that it did work for a couple of years. I just moved into a new studio, and set it all up, and now my iMac won't recognize the fireface. It does "connect" though, since the iMac is actually able to power the card via bus power. I figured that it might be a problem with the signal being too weak, so I tried using the external power cable for the sound card instead. The card worked for something close to 2 minutes, and then went back to the passive state with the host button on. I was able to update the firmware, at some point when the card was recognized, for a day or so. First it didn't work for a couple of hours, then I got it running, updated the firmware, and like a day later it stopped working again. I don't think this is related, but I just want to rule out the obvious update driver/firmware sollution.
I've searched the net pretty thoroughly, and noticed that a bunch of people seem to have problems similar to mine. For most
people resetting the PRAM/NVRAM seems to do the job, and in some cases resetting the SMC (by unplugging the power cable and everything else) works. I've tried both of these 3-4 times, but it hasn't worked.
Other people claim that there is a problem with the chipset installed on a certain generation of imacs around the time I bought mine. It doesn't seem that this is the case with mine however. Consulting the RME forum suggests that my chipset is good enough, and since it worked for a couple of years I find it hard to believe that the computer suddenly realized that the chipset actually couldn't run this specific soundcard.
The soundcard is tested on other computers and works flawless.
So. What do I do. Running to my nearest retailer with a computer that seems to be working just fine in pretty much ALL aspects seems a bit ridiculous, and will certainly be a last measure, and something I will only do if I'm sure that the port is actually damaged in some spacy way.
What i've tried so far:
Resetting PRAM/NVRAM (several times)
Resetting SMC (several times)
Starting up in boot camp (the card isn't recognized here, so it's probably not a OS issue)
Uninstalling all drivers and reinstalling.
Installing older drivers to see if they would work
Updated both the mac software, the fireface firmware and the fireface drivers (currently everything is fully up to date)
Specs:
Hardware Overview:
  Model Name:    iMac
  Model Identifier:    iMac9,1
  Processor Name:    Intel Core 2 Duo
  Processor Speed:    2.66 GHz
  Number Of Processors:    1
  Total Number Of Cores:    2
  L2 Cache:    6 MB
  Memory:    4 GB
  Bus Speed:    1.07 GHz
System Version:    Mac OS X 10.5.8 (9L30)
  Kernel Version:    Darwin 9.8.0
  Boot Volume:    Macintosh HD
  Boot Mode:    Normal
Please help a brother out!
Re: Fireface not recognized on imac - "Host" light constantly on.
Short version: interface works for a longer time on a different computer even using bus power. On your iMac it fails after a short time, even with external power supply. Correct?
Please try a different FireWire cable.
Thank you for your answer. Unfortunately the fireface was connected to the other computer with the same cable, so it seems unlikely that the cable is defect.
None the less, try a different cable.  What is adequate on one system may not be on another.
I will of course, when I'm in the studio later. I really hope that's all it takes.
In case somebody runs in to the same problem: This was solved by upgrading from Leopard to Snow Leopard.
Hi Solar
I have exactly the same problem, as you have (had). You said that it helped upgrating to Snow Leopard, so I did, and I have done all the things, you have done to resolve the problem:
-Resetting PRAM/NVRAM (several times)
-Resetting SMC (several times)
-Uninstalling all drivers and reinstalling.
-Installing older drivers to see if they would work
-Updated both the mac software, the fireface firmware and the fireface drivers (currently everything is fully up to date)
-Update from OS X Leopard to Snow Leopart
But still no changes!
I too have tried the interface with a macbook, where it works great.
You wouldn´t have further suggestions on how to fix this, would you?
-Phaedrus.
Phaedrus, does any other FireWire device work with your mac?
