Topic: Which Card For Digital Coax (RCA) Out?
Looking for a simple (i.e. least expensive) card with support for digital coax (RCA) out in 24/192. No other output interfaces required. Which card in the RME line would I choose?
RME User Forum → HDSP(e) series → Which Card For Digital Coax (RCA) Out?
FYI, PCIe preferred, just need to send the signal out to an external DAC via digital coax, so no onboard DAC, or analog output support required.
No such card, sorry... I would suggest to check if your onboard sound has SPDIF capabilities, or if there is an inexpensive USB solution with SPDIFonly...
