Topic: Pro Tools & FF800. Any issues to be aware of?
Going to install PT10 on my system* this weekend with the intention of using my FF800 instead of the MBox Mini that PT was bundled with. An Avid sales rep told me that they don't test 3rd party interfaces so with that in mind, are there any issues or caveats I should be aware of?
Peter
* System Specs:
• Mac Pro 2 x 2.4 G Quad Core Xeon
• 20G RAM
• OSX 10.6.8
FF800
• Total Mix version 2.93
• FireFace Version 2.77, Kernel driver v2.93
• Connected to 3rd party FW PCI-e card via FW400
MacPro (5,1) 2010 8-Core 2.4GHz | 32G RAM | OSX 10.6.8 | FF800
Re: Pro Tools & FF800. Any issues to be aware of?
There should be no problems, assuming FW is working correctly on the system.
Thanks Jeff. :-)
Make sure you have the latest Fireface drivers and when you first start up, go into the I/O config and select default for the inputs, outputs and busses tabs so that it will detect and configure all of your gazintos and gazoutas and you should be good to go.  I use two of them and a UFX with PT 10 and everything is rock solid on both a desktop and mobile laptop with Win 7.  Good luck.  I think you will enjoy the quality too!!
It works a treat!!!
Matt McKenzie-Smith (UFXII, UFX, Babyface) MacStudioUltra OS13.2.1
