Topic: Test Template for Live band trio with Lemur and UFX
As suggested by David in an other thread, I try to program a little live set template for my trio.
You will find underneath, the beginning of our conversation and even lower the images and the links to the template project.
Philippe
Hello Neirbod,
I am more and more interrested by a control surface for my UFX. I first thought I would go for a BCF2000, but the ipad seems a better option for me (lighter, I can tighten it to a mic stand, have my sheet music on it, other apps as "Everyday looper" interrest me ...).
So I think I will wait a little for the iPad 3 and use Lemur.
I was also very concerned about the rotary encoders of the Lemur App, and I downloaded the free Lemur Editor for PC and programmed a 3 pages layout for testing.
The Rotary Encoders have different "Behaviours" options : If you choose the "standard behaviour", it is very dangerous (you can go from 0 to Max in just a little horizontal micro motion, I also plan to adjust the gain of the mics and it cannot be that way !.
I found the following options of the object "Knob" much more reasonable : I chose the following behaviors : CursorMode = Limited / Control = Linear and Physics = None, and it is perfect : If you need to adjust the gain, you must clic inside the knob or just on the rotary area, and slide vertically without any risk. if you move sideways, it has no effect and the speed of the thing can also be controled.
If you want to try it easily, you can download the free editor and test it yourself (you can emulate an iPad and the touch with your mouse).
If needed, I can also send you my template for the "live Set" (if it really can do what I programmed, it is Exactly what I need to drive my UFX standalone on stage !!). I even programmed a "Reverb" and "Echo" button, with all the options that are grey when inactive, and everything in colors when active (don't know if I will be able to do that with UFX commands for the standalone beast... but at least it works on the Lemur !)
Hi Philippe,
Thanks for the info on how to create a safe rotary encoder! That is very good news.
I (and I think others) would be very interested in any template you developed for live use. May I suggest that you start a new thread specifically to discuss Lemur and post the template there? I would not want this good information to get lost in this more general thread. Or if you don't want to post it on the forum please send it to me in an email. I am waiting on the iPad 3 (I borrowed an iPad 2 from a friend to test TouchOSC) so it will be a few weeks before I can get one and try it. In the meantime, that is a good idea to work with the editor. I will do that.
Cheers,
David
Screen of the iPad for the main output :
[img align=C]http://lepetitgroupedumardi.free.fr/1.jpg[/img]
Screen of the iPad for the effects (for example when Reverb is ON and Echo is OFF)
[img align=C]http://lepetitgroupedumardi.free.fr/2.jpg[/img]
Screen of the iPad to set the singer's mix
[img align=C]http://lepetitgroupedumardi.free.fr/3.jpg[/img]
The link to the lemur template is here : Link to the Lemur Template
