Topic: Scroll bar for Total Mix window?
I just started using Netbook to set up some parameters in Total Mix for DUREC/UFX recording. The netbook has 600pixels for vertical resolution, so it barely displays analog in and hardware out in two-row format. But the recorder buttons were down below, and several options on the right side need to be collapsed to be able to see the recorder buttons.
So the question is, is it possible to add scroll bar for the Total Mix window, so that I can use three-row format, and recorder buttons without collapsing other options?
If this question has been already addressed, please let me know where is the thread.
Thanks!
Masaaki
