1 (edited by bonis 2012-03-01 14:10:20)
Topic: Fireface 800 - Window 7 - 64 bit driver
I would like to know if any libraries/modules that make up the driver for the ff800 are native 64-bit (@ 64-bit operating systems),
i found that some dll are resident in system32 folder (Windows 7 - 64 bit),
when i work an 64-bit operating system the driver works in 32-bit ?
when i work an 64-bit operating system the Fireface settings and the Fireface mixer works in 32-bit ?
Bonis
www.bonisaudio.com
Re: Fireface 800 - Window 7 - 64 bit driver
The settings and mixer applications are 32 bit... This has nothing to do with the driver as such.
....has nothing to do with the driver as such
ok, but the driver is 64 or 32 bit ?
was expected soon or later a full 64-bit of setting and mixer applications ?
www.bonisaudio.com
bonis wrote:
ok, but the driver is 64 or 32 bit?
64...
No, there is no need for that.
Daniel, thanks for your answers,
you have tested in real world the 32 and 64 bit versions for be sure it is useless or your noun is only theory ?
www.bonisaudio.com
There are no 64-bit versions of these applications.
thanks, one last question, the Fireface mixer user settings are stored in a file or in registry for windows 7 ?
www.bonisaudio.com
