Topic: Fireface UCX standalone midi control
Hello I'm investigating the capabilities of the UCX to be controlled from a midi console such as the Behringer BFC 2000, without the need of going through a computer. I can't figure out clearly from the manual if it's possible to control all of the DSP parameters, or is it limited to some of them. Thanks for prompt answer
Re: Fireface UCX standalone midi control
None of the DSP parameters can be controlled this way, only the mixing/routing.
