Topic: MFace2 and Digiface Sync Questions
Into unchartered territory: adding a Digiface to my Multiface 2 setup.
I had an existing PCIe for the MF2, but had to add a PCI for the DF, as I had run out of PCIe slots.
1. Does it make any difference which card is connected to which device? In other words, would the DF be better connected to the PCIe as it will have more through put?
2. Are all the sync options equally reliable/ preferrable, or not? I'd prefer to use Word Clock as I don't want to give up any possible channels as I would with S/PDIF.
3. If using Word Clock, do I need to set any termination between the DF (interna/ master) and MF (Word Clock/ slave), internally or with external termination, or is that unneccesary if I'm just using these two?
(BTW the DF will be hooked up to the ADAT on a Allen & Heath ZED R16, which only has the ADAT i/o and no other sync connection option. I must presume that this will sync through the DF.)
4. If I run a third bit of digital gear using the BNC T Terminals, what is the best way? Set the other item between the MF2 and DF, or after with termination?
5. Why would I (or would I not) want to use Single Speed with Word Clock? I read what it does, prevent doubling on SMUX, but I don't understand when I should or shouldn't use it.
Thanks for the help!
bienpegaito
