Topic: UCX -Switched from USB to FW - now no audio
Worked fine through USB but I wanted to try FW. Have a Lacie FW800 (TI chip) with 800 to 400 cable. Installed and updated firmware and drivers via USB per instructions. Reconnected FW only. Windows 7 playback device set to SPDIF/ADAT (1+2) and it shows signal in control panel>sound>playback window. Optical cable connected to UCX SPDIF, faders/inputs as they were when connected via USB but no sound and no signal in TotalMix FX.
I've seen in other posts the recommendation to try both if one experiences pops/clicks so I assume there are no issues switching. Is there something else that needs to be done because of the switch?
I've been out of the recording loop for a while and I'm new to the UCX so perhaps I'm missing something simple. Any suggestions?
