Topic: FireFace Mixer / Routing problem on headphones
Hi guys
The following signal path:
1. DAW out - Fireface out - Hardware processors- Fireface in - DAW in
In my DAW I use out 3-4 and then back in on 5-6 which goes out on speakers via master out 1-2.
The problem:
The chain works perfectly on my speakers. I hear just my master output 1-2.
If I try to check the signal in my headphones (FF400) I hear two signals. I think the one going to the hardware processors AND the master output.
How can I fix that?
Thanks a lot.
Cheers
Alecx
Re: FireFace Mixer / Routing problem on headphones
http://www.rme-audio.de/forum/viewtopic.php?id=5039
