Topic: Output assignment
I recently uploaded the latest driver, as I apparently was not up to date
All existing session  when opened the outputs is now all Analog 1/2 (or whatever it now says  Analog 1-8-1/2
anyway I use SPDIF 11/12 and pretty much always have
I have to manually change each of my outputs before I  can begin a session and hear through my monitors.  Also the inputs are changed, although this isn't as much an issue as older sessions have recorded tracks....
If I start a new session from my templates, everything is fine.
I'm running DP7.24 and all sessions were made in DP 7.
Is there a way to set the default output to SPDIF 11/12?
Re: Output assignment
That would be a DP question. You can, however, set the routings in TotalMix so all playback channels are routed to SPDIF out.
according to DP, it recognizes what I/O's are active available, but has no preference/default
I'll try setting Total Mix playback to SPDIF . I have the Hearback system so I do not use TotalMix anymore.
folks in the studio can adjust their own dang mix!
