Topic: Genelec 8020b + 5040a + Babyface
Im planning on getting some new monitors, namely the Genelec 8020b, possibly with the 5040a sub.
I was wondering if it would be possible to send outputs to both separately. ( Firstly to spare the housemates of constant bass, and second just to check either or alone )
Would be nice if I could do this straight from Babyface without no extras.
So can you: Send normal outputs to monitors, and use the breakout cable headphone output to send to the sub?
This would all obviously be controllable from the Babyface unit which would be perfect for setting levels.
Any tips welcome. Thanks
Re: Genelec 8020b + 5040a + Babyface
Since line and headphone outputs are separate and separately controllable, you can certainly do so, e.g. with mixer snapshots.
