Topic: loopback feature newbie
hi i just found out about the loopback feature i would like to know if i am using the loopback feature to record from software instruments to audio and the card's sample rate and the project's sample rate are both set to lets say 96kHz is the audio recording going to be recorded at that sample rate and am i using the card's converters to record the audio.Sorry if the question seems like a silly one i'm a newbie. Thanks in advance
kind regards
latoya
Re: loopback feature newbie
Loopback does not use converters, it takes place inside Totalmix. Incoming signal will be of the same sample rate.
Thank you so much for the reply sorry to be a bother but I would like to know if there is a way to send my  software instruments through the card so that they would use the sound cards converters I don't know if that would make a differance but I love the rme converters.
kind regards
Latoya
