Topic: ff400 and external reverb
hello,
i connected a microfone to input 1 and a MX200 Lexicon reverb unit via coaxial SPDIF (line 9 and 10, i hear the audition samples)
how can i route the mike so to have the voice with effects in the headphones?
i watched all the youtube videos but i couldn't figure out...
stupid from me, i know...
thanks
Mauro
Re: ff400 and external reverb
mauro05 wrote:
hello,
thanks
Mauro
In totalmix you need to route input one to hardware (bottom row) outputs 9 and 10. Then you need to route inputs (top row) 9 and 10 to your headphone output. You also may want to experiment with changing the balance between the dry (input 1 top row) and wet signal (input 9 and 10 top row).
Hope this helps,
Isaac P
3 (edited by mauro05 2012-04-16 19:38:29)
thanks, solved: the MX200 unit was selected with analog inputs by default, i switched to digital
all fine
Mauro
