1 (edited by autogen 2012-04-20 02:23:37)
Topic: 2 X FF400 (via ADAT) Help Please!
I recently purchased another FF400 to double up on my IO. I have been trying to connect them both with one as standalone simply hooked up via toslink, but after seemingly working it out last night I can't get it working again for the life of me.
I am setting up the standalone FF400 first via firewire and storing settings and Total Mix settings to the internal flash memory.
I have made all necessary toslink connections.
I can see signal in the Total Mix window on the ADAT channels, but neither Logic or Live can see a signal on these channels? However they can both see a signal from the master FF400 inputs.
Here are my settings for the Slave (standalone) FF400:
http://www.autogenesisdesign.co.uk/storage/Slave.jpg
Here are my settings for the Master (connected to MBP via firewire) FF400:
http://www.autogenesisdesign.co.uk/storage/Master.jpg
Can anyone see what I'm doing wrong? I presume I am missing something in the Total Mix settings?
I'd be most greatful for some help on this, it's driving me nuts at the moment!
Re: 2 X FF400 (via ADAT) Help Please!
The images haven't seemed to have worked here, if you right click and 'open in new window' on the image error icon you can see them though... is there a pixel dimension limit for images here or something? I'm pretty sure I've got the tags right.
3
If you look again you will see that you limited the master to Analog+SPDIF. No ADAT possible then...
Thanks! I can't believe I didn't spot that... strange though, I'm now getting signal from Channel 1 in Live, but still not 3 & 4?
