Topic: Fireface UC Toslink cable problem
I connect Quik lok cfo-10 toslink to adat in Fireface Uc,and then could not pull this cable from UC.Its this cable not appropriate?
I thought that Toslink Cables is standart?
Help with this problem?
Many thanks
Re: Fireface UC Toslink cable problem
From what I findd on Google, this is a regular thin Toslink cable, there should be no problem... Can you see what is blocking the cable? Can you try moving it a bit while pulling?
I'll try to do it.
Thanks for help
