Topic: Multiface jumper settings (again).
I have a total trouble with understanding the multiface (I) manual. Its all because terms "factory defaults" and "Bend the flexible shield carefully upwards" - its made me mad. I don`t know, which was factory defaults. And "bend" means "flip the cover" or "move up a little".
So, can any one say: on which side of the pin group will be +4dBu setting as i look at the board as shown on the picture?
http://e-city.kiev.ua/p/IMG098.jpg
(unit placed front panel to the front)
Thank You.
Re: Multiface jumper settings (again).
From the manual:
A drawing showing the jumper position for each level setting is found on the left side (underneath
the flat cable) on the analog board.
FACEPALM! THANK YOU! IT IS AMAZY!
Now I`m happy.
4 (edited by Diggers 2018-06-13 14:15:31)
From the manual:
..but that doesnt clearly answer the question.. depends which way round we are looking at the drawing/board.. (presumably we read the drawing looking at the board from the side the drawing is printed, but this isnt stated anywhere I can see)..
most clear way is to look at the above photo and say what the setting is with the jumpers as in the photo... I think he has them set to "Lo gain"..?  also confusing, on the drawing it says "Lo/Hi gain" ... where is the "Hi gain" setting?
