Topic: Help needed - routing question, UFX/Hilo
Greetings,
I recently bought the Lynx Hilo, which I am using alongside the RME UFX.
I am tracking in using the UFX, and monitoring my main output using the Hilo.
The problem is, I can't use direct monitoring of my UFX inputs with this configuration, can you recommend how to route the input signal on the UFX directly to the Lynx outs? I am trying to acheive latency free monitoring through the Hilo, so I can still sequence my hardware synths without sloppy timing.
Thank you for your time,
MR
