Topic: Ff800 channels listed incorrectly in lion 10.7.4 audio midi setup app
I updated to 10.7.4 yesterday and the ff800 ports are listed incorrectly in the mac audio set up app. In particular itis the spdiff (normally on 11&12) being listed to output on phones channels (9&10).
I do not know if this is a recently introduced bug in 10.7.4 or  an error on my part. I have two systems, one being 10.7.3 and it works as expected. Please advise.
Re: Ff800 channels listed incorrectly in lion 10.7.4 audio midi setup app
Here is a screen shot to illustrate:
http://i50.tinypic.com/ejj0iq.png
When I select SPDIf the driver is selecting Phones 9 and 10, my whole system has to be altered because of this bug.
Any ideas how to resolve?
From my 10.7.3 system, hooked up to the same ff800 it shows correctly:
http://i50.tinypic.com/33eokk3.png
I can confirm this problem, same issue.
Upgraded to OSX 10.7.4, SPIF has moved.
I have been using the ff800 for over a year without issue, this is new with 10.7.4 OSX .
Suggestions/fixes appreciated.
Confirmed here, will forward this... Hope it is something we can fix on our side.
For the record- same issue here on Fireface UFX, after update to 10.7.4...Headphone outputs moved to channel 27-30, AES out on 9-10, ADAT 1 on 11-18 and ADAT 2 on 19-26.
regards
Many thanks to those confirming the issue. At least I know it isn't just me.
8
The new driver 3.07 should fix the channel shift under 10.7.4 and still be compatible with OS below 10.7.4:
https://archiv.rme-audio.de/download/fi … 07_x86.zip
Note for UFX and UCX users: 3.07 comes with TotalMix FX 0.97, which requires 10.6 or up!
Thank you, all is as before :-)
