1 (edited by coder2k 2012-05-16 20:47:45)
Topic: [Bug?] in TotalMix FX using the expander (Fireface UFX)
received my Fireface UFX today. Installed latest driver and firmware. I found that when I set up the expander (in my case for Stereo in 5/6) and store the snapshot -> when I reload the snapshot, the ratio control always goes back to 1.0 instead of the value I choose before. Am I doing something wrong?
Hope this is no double-post...I searched the forum but didn't find a similar thread.
Michael
EDIT: I'm on Windows 7 (64 Bit) and using the UFX over USB.
Re: [Bug?] in TotalMix FX using the expander (Fireface UFX)
I can not reproduce. Can you tell us which firmware, driver and TotalMix version you use?
I use USB Driver version 1.022, Hardware Revision 352 and TotalMixFX version 0.971.
Still no solution?
5
> I can not reproduce
So what 'solution' do you expect? Did you try the latest TM FX 0.98 from this forum?
Please check 0.98 RC1 for Windows, link in first post:
http://www.rme-audio.de/forum/viewtopic … 124#p73124
We think we fixed it.
After re-saving the snapshot under the new version it now works! Thank you!
And now just because I think you gonna read this: Is it a bug or on purpose that the speaker pair B cannot be switched to mono? No offense, just asking.
Thanks again!
8
You tried with this version?
Yes, but only works for the main speakers, not for speakers B (while the mute switch works for both).
10
It works for me. Which channels are assigned for Main and B?
Main is AN 7/8, Speaker B is AN 1/2
12
Confirmed - thanks for the info.
You're welcome smile
14
Fix:
https://archiv.rme-audio.de/download/to … 981rc1.zip
That was quick! Thank you, works perfectly!
