Topic: Babyface Speaker B Setup
I have had my BF for a number of months now. I have it connected to an Apogee AD-8000 using the ADAT optical connections. Everything works great and sounds fantastic.
I would like to set up Speaker B so I can use a 2nd pair of monitors. I have the Main Output Assignment going to AS1/2 (the first stereo output pair of the AD-8000). For Speaker B I would like to use AN1/2 (the analog outputs of the BF). When I select it, a new master fader comes up and it is set to be linked to the Main Output fader.
Only issue I am having is that when I select Speaker B, the rotary encoder on the BF no longer adjusts the level. When I have Speak. B deselected, the rotary encoder controls the Main Output and the Speak. B output fader tracks it just fine.
Am I missing something here? I am using TotalMix FX ver. 0.97 MAC OS X (1) with Mac OS X 10.7.3
Thanks in advance for any input or advice you all may have.
