Topic: Multiface 2 connecting with Bricasti M7 V2 through Digital AES/SPDIF
Hi everyone,
Can you please help me, as I am not seeming able to find the combination that works for this. I can successfully make the two work perfectly with Analog connections. Just not digital.
The Bricasti offers XLR AES INPUT and XLR AES OUTPUT. I am trying to connect those to the SPDIF COAXIAL connections on the RME Multiface 2. What would be the correct configuration for that (on the Mtuliface 2)? Here is what I have tried so far.
1. COAXIAL SPDIF input and output cables to XLR AES INPUT/OUTPUT connections on Bricasti M7. Then I changed the internal clock source to SPDIF IN and it only locks at 32000HZ no matter what I do. This causes the Bricasti to sit there saying digital status unknown.
2. If I try to use any other clock source besides SPDIF IN, I get massive feedback through my monitors. (I do not have my DAW open, nothing is open except the RME Control panel and totalmix).
3. I have sent the SPDIF output to the Bricasti M7, but then sent the Bricasti OUTPUT to my Lavry DAC instead of back into the Multiface 2 and it worked perfectly! The problem is, this doesn't help me get my audio returned into my DAW haha.
I want to route the Bricasti to and from the multiface 2 using the SPDIF Coaxial connections. My Lavry DAC is connected via ADAT optical. Here are 2 screenshots of my RME DSP Settings Control Panel and driver.
http://www.mediafire.com/i/?4e86na1s887x7j6
http://www.mediafire.com/i/?temcq2vetm2qszi
Can someone please help me make this work, I would very much appreciate it.
Windows 7 64-bit, i930 Processor, Cubase 6.5
