Topic: Fireface UFX: Controlling volume on all 8 balanced outs using VOL knob
Hi there,
I just purchased a UFX and plan to use it primarily as a multi-channel DAC+preamp for an active speaker setup. My computer is doing crossover duty, and the UFX receives separate signals for sub, bass, mid and tweeter that are then fed to dedicated amps for all the drivers.
I need to keep the gain for all 8 channels in sync, and while it's doable in software I'd prefer if I could use the physical volume control as well. As far as I can tell that is not supported today, is that correct? If so, is it possible that it may be supported in a future version of the firmware?
Thanks for an amazing product.
Gvr
