Topic: FF400 problem.
m hooking it up to my macbook pro OSX 10.6.8. I cant quite remember the date of this computer but I remember I got it (new) not long after the new shape came out. I have downloaded the latest drivers and firmware.
Here’s what’s happening:
In logic pro, i tunes and any other sound source I hear occasional short bursts of sound and that’s it! I am just listening through the headphones at the moment as my monitors are all packed away for a house move. In logic I get an error message saying "synchronisation error sample rate 431230 (this number varies) detected......"
The fireface is set to 44.1 (as is logic), Master, word clock
Re: FF400 problem.
anyone? - i have found people raising similar problems but no responses that fix mine. in properties Iv 3.08 unit 1.71. the red host light is flashing on the unit. Nothing seems to change that. someone please help!!
Re: FF400 problem.
Sounds like your MBP has the defective Agere FW chipset:
http://www.rme-audio.de/forum/viewtopic.php?id=4986
http://www.rme-audio.de/forum/viewtopic.php?id=1475
Re: FF400 problem.
thanks. i have tried connecting it through my External lacie HD using 2 x FW400 - 800 Leads. still the same problem. do i have to use that particular cable? Also, im not sure i actually understand the link you sent me?
Re: FF400 problem.
What model/year is your Macbook Pro?
Re: FF400 problem.
Hi. it is a MacBook Pro 15-inch, Late 2008
Re: FF400 problem.
Then it's likely to have the FW chipset problem mentioned in the form threads linked above.
Re: FF400 problem.
I'm having the same problems with intermittent disconnections and the red light / host. What's going on with my ff400?
9 (edited by worldshed 2012-06-09 11:51:12)
Re: FF400 problem.
Hi
I have gone through these links. i have tried a fw400 - 800 cable direct to the computer and via a lacie external hard drive using 2 x 400 - 800 cables. still the same problem. am i missing something? Is there something else i need to do?
martin
10 (edited by 7thkey 2012-06-11 21:40:03)
Re: FF400 problem.
Please, I need support. It has nothing to do with what is mentioned in that thread.
I can't work with this strange behavior.
My FF400 only has 2 years and one month old.
My specs: Macbook Pro 15" late 2007 commonly known as Santa Rosa., Dual Core 2.4, 6GB RAM, TI FW based chipset.
Tested on Lion 10.7.4, Bootcamp Windows 7 and of course using RME FW400 cable and another cable LaCie FW400->FW800 with the same results except for the Windows system that disconnects over longer periods...
Adding to the test I've tried with another modern laptop, Macbook Pro 15" late 2010 with Lion 10.7.4
I forgot to mention that all tests have been made with the latest drivers, firmware and repaired permissions.
Why is this happening?
Any ideas?
Re: FF400 problem.
worldshed wrote:
Hi
The late 2008 Unibody Macbooks use the FW chipset that is buggy. If your Lacie drive does not bridge the interface properly then your best bet is to get the Lindy FW repeater cable. It worked flawlessly when I had that MBP and now is still in use on new models to extend cable length.
Re: FF400 problem.
Then congratulations on hijacking a thread that has nothing to do with your specific issue. fryingpan
Did you try a different Firewire cable yet?
Re: FF400 problem.
Hi Timur, thanks for responding.
Like I said briefly in my previous post, I used a new cable LaCie FW400->FW800 on a FW800 port on MacBook for another testing and the audio is turned off and on every few minutes at random, may be periods of 1 or 5 minutes.
I've tested the cables with external hard drives and it seems to operate properly.
14 (edited by Timur Born 2012-06-12 12:47:54)
Re: FF400 problem.
If the disconnect happen with different cables on different computers and different operating systems then it seems likely that your Fireface might be broken. Best to contact your local dealer (or RME distributor) and ask them for an analysis. As far as I remember this costs 35 EUR in Germany (Daniel, correct me if I'm wrong), so it's neither free nor too expensive.
Re: FF400 problem.
Timur Born wrote:
worldshed wrote:
Hi
Is there a particular brand thats best?
Martin
Re: FF400 problem.
You can get the Lindy cable from Lindy: http://www.lindy.com/ wink
