Topic: Can't install the UCX USB driver on Windows 7 64 bit
Windows identifies the UCX as "Unknown Device" under the "Universal Serial Bus Controllers" device group.
I'm trying to manually update the driver. I'm using the latest USB drivers available on the web site (from 5/3/2012).
I'm pointing Windows to fireface_usb.inf and I'm getting the following error:
The folder you specified doesnt contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for x64-based systems.
Are there any other drivers?
Please Help!!!
thanks!
