1 (edited by doctorwho 2012-06-25 22:19:50)
Topic: Cubase outputs stereo to HDSP mixer and physical output is mono...
Hello.
I have RME HDSP 9632 and I'm very happy with it.
The only problem is when I output stereo sound from VST host to a separate channel in HDSP mixer then mixer mixes it as mono...
see picture....
Really weird problem stereo becomes mono...
if you look at the pic you will see that a7 and a8 have stereo signals (panning for each set left and right out 11 and out 12)
and then in an1 ans an2 you see it becomes same signal....
[img align=R]http://i46.tinypic.com/21dkay1.jpg[/img]
Re: Cubase outputs stereo to HDSP mixer and physical output is mono...
Click on the Submix button on the top right, then the problem (pans in the middle row) should be obvious when AN 1/2 submix is selected.
well, looks like i got whre i wanted to be after routing matrix like this[img align=r]http://i45.tinypic.com/5u0dqf.jpg[/img]
for some reason i still cant understand what you mean
smile
1+2 that's analog out right?
First do as Jeff says, there is a submix button, now grey under view top right. Then you can select AN1+2 and you can then see how pan is set up
and where exactly I see that?
in the middle row, the panners above the faders. But only in submix mode
